ESP8266 01S Flashes and runs but no serial output
PostPosted: Fri Jan 25, 2019 12:36 am
by 3v0
This has gotten a bit long but I fear that if I don't provide enough detail much time will be wasted on going over what I have already looked at. Thanks.
S01 + relay modules from AliExpress. The ones that require a jumper and a resistor mod to the relay board. "ESP8266 ESP-12 ESP-12F CH340G CH340 V2 USB WeMos D1 Mini WIFI Development Board D1 Mini NodeMCU Lua IOT Board 3.3V With Pins"
I have them working on a breadboard, no relay, and on a patched relay module. The WiFi/webpage is working but the serial is not. Given that I can flash the ESP I can't see where there is a hardware problem. To 2X check I looked at the TX pin and see no pulses after programming is over, so not a baud rate problem.
Seems one can re-purpose TX and RX as digital IO and they can be changed back to RX, TX. But adding this seems to keep the program from running. That is I can not connect to it on the web. No joy.
Code: Select all//********** CHANGE PIN FUNCTION  TO TX/RX **********
//GPIO 1 (TX) swap the pin to a TX.
pinMode(1, FUNCTION_0);
//GPIO 3 (RX) swap the pin to a RX.
pinMode(3, FUNCTION_0);
Tried Serial.begin with these parameters and the program still works no serial output. Any ideas ?
 Serial.begin(115200,SERIAL_8N1,SERIAL_TX_ONLY);
The sketch I am using follows, not mine.
#include "Creds.h"
//const char* ssid = "YOUR SSID"; // fill in here your router or wifi SSID
//const char* password = "YOUR PASSWORD"; // fill in here your router or wifi password
 #define RELAY 0 // relay connected to  GPIO0
WiFiServer server(80);
void setup()
  Serial.begin(115200); // must be same baudrate with the Serial Monitor
  pinMode(RELAY,OUTPUT);
  digitalWrite(RELAY, LOW);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("https://192.168.1,55/");
  Serial.print(WiFi.localIP());
  Serial.println("/");
void loop()
  if (!client)
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available())
    delay(1);
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("/RELAY=ON") != -1)
    Serial.println("RELAY=ON");
    digitalWrite(RELAY,LOW);
    value = LOW;
  if (request.indexOf("/RELAY=OFF") != -1)
    Serial.println("RELAY=OFF");
    digitalWrite(RELAY,HIGH);
    value = HIGH;
  // Return the response
  client.println("HTTP/1.1 200 OK");
  client.println("Content-Type: text/html");
  client.println(""); //  this is a must
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<head><title>ESP8266 RELAY Control</title></head>");
  client.print("Relay is now: ");
  if(value == HIGH)
    client.print("OFF");
  else
    client.print("ON");
  client.println("<br><br>");
  client.println("Turn <a href=\"/RELAY=OFF\">OFF</a> RELAY<br>");
  client.println("Turn <a href=\"/RELAY=ON\">ON</a> RELAY<br>");
    client.println("</html>");
  delay(1);
  Serial.println("Client disonnected");
  Serial.println("");
