A converter does not give enough intensity with
I succeeded with
But the controls are reversed (not serious) and when the engine stops through R2 28 mA and when running is 4mA.
How to reverse so that at rest we have a weak current ?
Explore... Chat... Share...
rudy wrote:If you are only trying to provide an input to the VNH2SP30 then you don't need to use 200 Ohms. Change the resistor to 2K2, or something at that level.
