By Jacek1
#83063 I have problem, that there is not "ready" after start. I have only in 74880bps:
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
rf cal sector: 507
freq trace enable 1
rf[112] : 03
rf[113] : 00
rf[114] : 01
SDK ver: 2.1.0(ace2d95) compiled @ Oct 24 2017 12:04:16
phy ver: 1134_0, pp ver: 10.2
I have IO0 in high state (also tried in float)
Everything was worked to moment when i sended to device:
"AT+UART_DEF=57600,8,1,0,3" so i turned on flow control.
Anybody have idea what is wrong?
What for is IO15? should it be in low or high state? (i tried both but program doesn't started).
By Jacek1
#83073
davydnorris wrote:The fact that you see the SDK and phy library versions means you have made it into user program space.
The command you sent dropped the baud rate to 57600, so you will need to change the tty speed in order to see more output after that
There is not any more data. with tty on 57600 i see only garbage. Earlier, before changing baudrate (there was 115200) there was "ready" after garbage.
