I am trying to upload EMG (Electromyography) signal to the Asksensors cloud using the ESP8266-12E nodemcu board. My circuit is really simple, I am using the myoware muscle sensor which is connected to A0, then vcc- 3.3 v, gnd-gnd. The issue is EMG signal needs a sampling rate of 1000 Hz (1000 discrete sample points in one second) but right now I am able to get only 10 samples per second because ESP8266 12 E takes 100 ms to update a data to the cloud. My arduino code and serial monitor output is as below. Is there anyway to do a faster update? OR is there any mistake in my code?
Please do help me. Thanks in advance.
#include <Arduino.h>
#include <ESP8266WiFiMulti.h>
// user config: TODO
#define MOISTURE_THRESHOLD 55 // moisture alert threshold
const char* wifi_ssid = "******"; // SSID
const char* wifi_password = "*******"; // WIFI
const char* apiKeyIn = "********"; // API KEY IN
const unsigned int writeInterval = 1; // write interval (in ms)
// ASKSENSORS config.
String host = "http://api.asksensors.com"; // ASKSENSORS API host name
ESP8266WiFiMulti WiFiMulti;
int moisture_Pin= 0; // Soil Moisture Sensor input at Analog PIN A0
int moisture_value= 0, moisture_state = 0xFF;
Serial.println("*****************************************************");
Serial.println("********** Program Start : Soil Moisture monitoring using ESP8266 and AskSensors IoT cloud");
Serial.println("Wait for WiFi... ");
Serial.print("********** connecting to WIFI : ");
Serial.println(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
Serial.print(".");
Serial.println("");
Serial.println("-> WiFi connected");
Serial.println("-> IP address: ");
Serial.print("MOISTURE LEVEL : ");
moisture_value= analogRead(moisture_Pin);
Serial.println(moisture_value);
if(moisture_value > MOISTURE_THRESHOLD) moisture_state = 0;
else moisture_state = 1;
// wait for WiFi connection
if (WiFi.status() == WL_CONNECTED){
HTTPClient http;
client.write(webFile);
Serial.print("[HTTP] begin...\n");
// Create a URL for the request
String url = "";
url += host;
url += "/write/";
url += apiKeyIn;
url += "?module1=";
url += moisture_value;
url += "&module2=";
url += moisture_state;
Serial.print("********** requesting URL: ");
Serial.println(url);
http.begin(url); //HTTP
Serial.println(">EMG were sent to ASKSENSORS");
Serial.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if(httpCode > 0) {
// HTTP header has been send and Server response header has been handled
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if(httpCode == HTTP_CODE_OK) {
Serial.println(payload);
} else {
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
Serial.println("********** End ");
delay(writeInterval);
}SERIAL MONITOR OUTPUT
-> [HTTP] begin...
17:19:43.421 -> ********** requesting URL: http://api.asksensors.com/write/Mh2ehZ0 ... &module2=1
17:19:43.457 -> > EMG data were sent to ASKSENSORS
17:19:43.457 -> MOISTURE LEVEL : 2
17:19:43.457 -> [HTTP] begin...
17:19:43.457 -> ********** requesting URL: http://api.asksensors.com/write/Mh2ehZ0 ... &module2=1
17:19:43.493 -> > EMG data were sent to ASKSENSORS
17:19:43.493 -> MOISTURE LEVEL : 3
17:19:43.493 -> [HTTP] begin...
17:19:43.493 -> ********** requesting URL: http://api.asksensors.com/write/Mh2ehZ0 ... &module2=1
17:19:43.493 -> > EMG data sent to ASKSENSORS
17:19:43.493 -> MOISTURE LEVEL : 2
17:19:43.529 -> > EMG data were sent to ASKSENSORS
17:19:43.529 -> MOISTURE LEVEL : 2
17:19:43.529 -> [HTTP] begin...
17:19:43.529 -> ********** requesting URL:
