Lipo Battery for Servo SG90 on ESP8266 nodemcu
Posted: Thu Apr 30, 2020 11:33 am
Hi,
For quickly describe my project.
I have build a weather station with some sensors and I use EspEasy firmware.
This station is powered with a LiPo 3.7v 800mAh.
This LiPo is charge by 2 solar panel (5v) and a module TP4056.
I control the current and power with a INA219
This project at this step, works.
But I want to add a SG90 servo motor for change the solar panel orientation.
After many tests my SG90 servo motor doesn't turn.
It turns when the battery is full charged and sometime it doesn't turn.
SG90 works well when I powered the ESP with the USB port but it's not the final expected behaviour.
After reading some articles, the conclusion is probably because the LiPo don't have enought intensity.
The SG90 want about 550mAh I think.
Have you already use a SG90 with a LiPo battery and have you a advice about the battery capacity I need ?
Thanks
Thanks
