initializing SD with ESP12E
Posted: Sun May 10, 2020 10:40 pm
Hello, first off im still new to all this and learning. I'm not sure if the ESP12E will handle connecting all this up properly. In the end I'm looking to have gps/sd/audio on the ESP. I'm connecting device by device and learning how to do that, I was able connect the audio board and get that working. However im having trouble connecting the SD board to the ESP. (alone).
Here are the devices im using.
https://www.amazon.com/gp/product/B07HF44GBT
https://www.amazon.com/gp/product/B07BJ2P6X6
https://www.amazon.com/gp/product/B01H5FNA4K
https://www.amazon.com/gp/product/B07PS653CD
According to this I have the sd board connected to GPIO 12-15. I validated by also writing the compiler variables for the board to serial, (SS, MISO, MOSI, CLK) and got the same gpio values.
https://images-na.ssl-images-amazon.com ... L1001_.jpg
Using this sketch example sketch to get info
With a sandisk ultra pro 32gb fat32 I get
* This program attempts to initialize an SD card and analyze its structure.
#include <SPI.h>
#include "SdFat.h"
#include "sdios.h"
using namespace sdfat;
// Set USE_SDIO to zero for SPI card access.
#define USE_SDIO 0
* SD chip select pin. Common values are:
* Arduino Ethernet shield, pin 4.
* SparkFun SD shield, pin 8.
* Adafruit SD shields and modules, pin 10.
* Default SD chip select is the SPI SS pin.
const uint8_t SD_CHIP_SELECT = SS;
* Set DISABLE_CHIP_SELECT to disable a second SPI device.
* For example, with the Ethernet shield, set DISABLE_CHIP_SELECT
* to 10 to disable the Ethernet controller.
const int8_t DISABLE_CHIP_SELECT = -1;
#if USE_SDIO
// Use faster SdioCardEX
SdFatSdioEX sd;
// SdFatSdio sd;
#else // USE_SDIO
SdFat sd;
#endif // USE_SDIO
// serial output steam
ArduinoOutStream cout(Serial);
// global for card size
uint32_t cardSize;
// global for card erase size
uint32_t eraseSize;
// store error strings in flash
#define sdErrorMsg(msg) sd.errorPrint(F(msg));
uint8_t cidDmp() {
cid_t cid;
if (!sd.card()->readCID(&cid)) {
sdErrorMsg("readCID failed");
return false;
cout << F("\nManufacturer ID: ");
cout << hex << int(cid.mid) << dec << endl;
cout << F("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
cout << F("Product: ");
for (uint8_t i = 0; i < 5; i++) {
cout << cid.pnm[i];
cout << F("\nVersion: ");
cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl;
cout << F("Serial number: ") << hex << cid.psn << dec << endl;
cout << F("Manufacturing date: ");
cout << int(cid.mdt_month) << '/';
cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl;
cout << endl;
return true;
uint8_t csdDmp() {
csd_t csd;
uint8_t eraseSingleBlock;
if (!sd.card()->readCSD(&csd)) {
sdErrorMsg("readCSD failed");
return false;
if (csd.v1.csd_ver == 0) {
eraseSingleBlock = csd.v1.erase_blk_en;
eraseSize = (csd.v1.sector_size_high << 1) | csd.v1.sector_size_low;
} else if (csd.v2.csd_ver == 1) {
eraseSingleBlock = csd.v2.erase_blk_en;
eraseSize = (csd.v2.sector_size_high << 1) | csd.v2.sector_size_low;
} else {
cout << F("csd version error\n");
return false;
eraseSize++;
cout << F("cardSize: ") << 0.000512*cardSize;
cout << F(" MB (MB = 1,000,000 bytes)\n");
cout << F("flashEraseSize: ") << int(eraseSize) << F(" blocks\n");
cout << F("eraseSingleBlock: ");
if (eraseSingleBlock) {
cout << F("true\n");
} else {
cout << F("false\n");
return true;
// print partition table
uint8_t partDmp() {
mbr_t mbr;
if (!sd.card()->readBlock(0, (uint8_t*)&mbr)) {
sdErrorMsg("read MBR failed");
return false;
for (uint8_t ip = 1; ip < 5; ip++) {
part_t *pt = &mbr.part[ip - 1];
if ((pt->boot & 0X7F) != 0 || pt->firstSector > cardSize) {
cout << F("\nNo MBR. Assuming Super Floppy format.\n");
return true;
cout << F("\nSD Partition Table\n");
cout << F("part,boot,type,start,length\n");
cout << int(ip) << ',' << hex << int(pt->boot) << ',' << int(pt->type);
cout << dec << ',' << pt->firstSector <<',' << pt->totalSectors << endl;
return true;
void volDmp() {
cout << F("\nVolume is FAT") << int(sd.vol()->fatType()) << endl;
cout << F("blocksPerCluster: ") << int(sd.vol()->blocksPerCluster()) << endl;
cout << F("clusterCount: ") << sd.vol()->clusterCount() << endl;
cout << F("freeClusters: ");
uint32_t volFree = sd.vol()->freeClusterCount();
cout << volFree << endl;
float fs = 0.000512*volFree*sd.vol()->blocksPerCluster();
cout << F("freeSpace: ") << fs << F(" MB (MB = 1,000,000 bytes)\n");
cout << F("fatStartBlock: ") << sd.vol()->fatStartBlock() << endl;
cout << F("fatCount: ") << int(sd.vol()->fatCount()) << endl;
cout << F("blocksPerFat: ") << sd.vol()->blocksPerFat() << endl;
cout << F("rootDirStart: ") << sd.vol()->rootDirStart() << endl;
cout << F("dataStartBlock: ") << sd.vol()->dataStartBlock() << endl;
if (sd.vol()->dataStartBlock() % eraseSize) {
cout << F("Data area is not aligned on flash erase boundaries!\n");
cout << F("Download and use formatter from www.sdcard.org!\n");
Serial.begin(9600);
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
// use uppercase in hex and use 0X base prefix
cout << uppercase << showbase << endl;
// F stores strings in flash to save RAM
cout << F("SdFat version: ") << SD_FAT_VERSION << endl;
#if !USE_SDIO
if (DISABLE_CHIP_SELECT < 0) {
cout << F(
"\nAssuming the SD is the only SPI device.\n"
"Edit DISABLE_CHIP_SELECT to disable another device.\n");
} else {
cout << F("\nDisabling SPI device on pin ");
cout << int(DISABLE_CHIP_SELECT) << endl;
pinMode(DISABLE_CHIP_SELECT, OUTPUT);
digitalWrite(DISABLE_CHIP_SELECT, HIGH);
cout << F("\nAssuming the SD chip select pin is: ") <<int(SD_CHIP_SELECT);
cout << F("\nEdit SD_CHIP_SELECT to change the SD chip select pin.\n");
#endif // !USE_SDIO
// Read any existing Serial data.
do {
delay(10);
} while (Serial.available() && Serial.read() >= 0);
cout << F("\ntype any character to start\n");
while (!Serial.available()) {
SysCall::yield();
uint32_t t = millis();
#if USE_SDIO
if (!sd.cardBegin()) {
sdErrorMsg("\ncardBegin failed");
return;
#else // USE_SDIO
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.cardBegin(SD_CHIP_SELECT, SD_SCK_MHZ(50))) {
sdErrorMsg("cardBegin failed");
return;
#endif // USE_SDIO
t = millis() - t;
cardSize = sd.card()->cardSize();
if (cardSize == 0) {
sdErrorMsg("cardSize failed");
return;
cout << F("\ninit time: ") << t << " ms" << endl;
cout << F("\nCard type: ");
switch (sd.card()->type()) {
case SD_CARD_TYPE_SD1:
cout << F("SD1\n");
break;
case SD_CARD_TYPE_SD2:
cout << F("SD2\n");
break;
case SD_CARD_TYPE_SDHC:
if (cardSize < 70000000) {
cout << F("SDHC\n");
} else {
cout << F("SDXC\n");
break;
default:
cout << F("Unknown\n");
if (!cidDmp()) {
return;
if (!csdDmp()) {
return;
uint32_t ocr;
if (!sd.card()->readOCR(&ocr)) {
sdErrorMsg("\nreadOCR failed");
return;
cout << F("OCR: ") << hex << ocr << dec << endl;
if (!partDmp()) {
return;
if (!sd.fsBegin()) {
sdErrorMsg("\nFile System initialization failed.\n");
return;
volDmp();
error: cardBegin failed
SD errorCode: 0X20,0XFF
