- erase whole flash via esptool (erase_flash),
- flash with last "esp_init_data_default_v08.bin" from SDK via esptool
- WiFi.disconnect() etc.
Each time looks that everythink is ok (no errors during flashing), but my module is not able to connect to any AP. If I run soft AP I'm not able to connect to it (I see SSID).
If I run basic example from wifimanager, the output is:
*WM: [1] No Credentials are Saved, skipping connect
*WM: [2] Starting Config Portal
*WM: [3] WIFI station disconnect
*WM: [3] WiFi station enable
*WM: [2] Disabling STA
*WM: [2] Enabling AP
*WM: [1] StartAP with SSID: AutoConnectAP
*WM: [2] AP has anonymous access!
*WM: [1] SoftAP Configuration
*WM: [1] --------------------
*WM: [1] ssid: AutoConnectAP
*WM: [1] password:
*WM: [1] ssid_len: 13
*WM: [1] channel: 1
*WM: [1] authmode:
*WM: [1] ssid_hidden:
*WM: [1] max_connection: 4
*WM: [1] country: CN
*WM: [1] beacon_interval: 100(ms)
*WM: [1] AP IP address: 192.168.4.1
*WM: [3] setupConfigPortal
*WM: [1] Starting Web Portal
*WM: [3] dns server started with ip: 192.168.4.1
*WM: [2] HTTP server started
*WM: [2] WiFi Scan completed in 2182 ms
*WM: [2] Config Portal Running, blocking, waiting for clients... I have question: should be the coutry code set to CN? I have change it to US, bo no difference. After restart again is CN.
I was also trying (at the beginning) wifi scan example, the output is:
scan start
scan done
1 networks found
1: ESP_CC23F1 (-68)
scan start
scan done
no networks foundWhy the module is finding only one network? At my place there is a lot of wifi networks. Is that a coincidence that every time is finding espressif network (different working nodemcu)?
How to recover the module?
