I used the example code from
https://embeddedcode.wordpress.com/2015 ... ller-code/
Has anyone successfully used serialEvent()
Tks
Explore... Chat... Share...
if (Serial.avaiiable()) serialEvent();It takes about 20-25 seconds for home assistant c[…]
