- Thu Jan 21, 2021 12:02 pm
#90292
Thanks for the reply.
I have searched all the forms and didn't got any proper findings. I have googled it very well and all of them have placed their module outside the switchbox.
I wish I could fit all these inside the switch board conceal box. The main problem I have to tackle now is the interference by keeping the module as small as possible.
I started with ESP01 find out it won't serve my purpose. It was sticking in between the code and not having watchdog resets.
Nest I tried with esp12E which has some shielding but that was resetting all the time.
Then I switched to ESP 12F which is kindoff. Not reseting even it's inside the switchboard box. Tried in multiple locations stable though. But when we try to switch it using the normal switch, it's getting instable bot not resetting. But when I give mqtt command it's working as expected.
I have used diode and capacitors to filter out for esp01 but later I used internal pull-up so it would save some space. If it's stupid please correct me.
Also I would like to know how the interference is causing only while usin the normal switch not from mqtt.
