I modded a ESP01 module (with Puya chip) to have the GPIO 16 pin connected to the RST pin. Also connected RST to VCC via an 10K resister to pull it up.
Using Tasmota firmware and the deepsleeptime command to make it fall in deepsleep.
This happens correct.
But it never wakes up. I connected my little osciloscope to it to measure if the RST pin is pulled low after a certain time and it happens (see attached image). So it seems the GPIO16 pin is doing its job correctly. But the module never wakes up. Anyone some tips to make this working?
Thanks,
Frank
