the 8266 serial port is configured to: 2400, SERIAL_8E1
the expected hex values would be: 68FAFA6853FF000167DB084B464D...............
the hex values i get: 68FAFA6853FF0167DB84B464D.......
so, there are missing "0" - for example after FF, after DB ....
the test prg i use:
ESP8266 Serial Communication
Serial.begin(2400, SERIAL_8E1);
// the loop function runs over and over again forever
if(Serial.available()>0) //Checks is there any data in buffer
Serial.print(Serial.read(),HEX); //Read serial data byte and send back to serial monitor
Serial.println("\n");
delay(1500); // Wait
}It seems the Parity Configuration would be ignored.
The right HEX Values I got from a python Prg on the Raspberry Pi.
