How can I have two "sensors" attached (plain old switches, which close to GND), and still support normal boot and boot into "flash mode"? This is using ESP8266 (or ESP-01).
The sensors (switches) are simple "door sensors", which detect if a door is open or closed by reading the corresponding voltage at the pin. The pins are, thus, pulled high (VCC = 3.3V) through 10K resistors, and if the switches are closed then the pins "see" GND. I can't know at any time what state the switches (i.e. doors) are in.
As I understand it, normal boot requires GPIO0 to be floating (or high), and GPIO2 to be high. Flash mode requires GPIO0 to be grounded, and GPIO2 to be high.
My first idea was to remap the RX pin as an input, and use that instead of GPIO0 -- dedicating this to a "boot select" switch. Furthermore, since we need GPIO2 to be high, I had the idea of having this switch simply toggle GND -- to either GPIO0 (boot) or the returns of the external switches. This way, when choosing "flash mode", we essentially disconnect the external sensors in the sense that -- if closed -- they are simply floating, and no longer closing to GND. This also solves the problem of RX (the new input pin) eating the data if that switch (SW2) would happen to be closed. Obviously, the remap (RX to input) only happens when my program is loaded, so the boot loader works as normal. This way, I can keep using TX for "debug output" from my program, to see what (if anything) is going on using a terminal software
The "//" in the drawing is to indicate that SW1 and SW2 are external sensors (connected by cables). Not that it matters...
For normal boot, however, this gives a problem. The selector switch will "move" GND back to the sensors, whereby leaving GPIO0 floating. That's good. But, once again we have the problem that GPIO2 needs to be high (during boot). If that switch (SW1) is closed, it now grounds the pin, and we can't boot the firmware.
My question is, how can I ensure that GPIO2 is high (or at least not ground) for the "time required" to do a normal boot? I was thinking maybe something could be done using a capacitor, which would keep the pin high for a brief moment while discharging, but I'm not sure if this is at all how stuff works.
I think this problem (of external sensors affecting boot) might be of interest, so I did this whole writeup. I know I could (probably should) upgrade to ESP32, but I like trying to figure this out...
