Problem with firmware update
Posted: Fri May 15, 2015 1:10 pm
Hi, I am new to this module ESP 01
I have connected the module as follows :
Vcc 3.3V
CH-PD 3.3V
RST floating
GPIO1 Gnd
GND Gnd
GPIO2 floating
Tx - to Rx (pin2) of DB9 connector
Rx-to Tx(pin3) of DB9 Connector
I am using Nodemcu for firmware update
I have selected the correct COM port since the log displays that the port is connected.
Also it shows that it is finding ESP8266
The blue icon keeps rotating. But the firmware is not flashed
The DB9 male connector is directly connected to the DB9 female connector on the CPU motherboard.
Can someone please explain as to why the firmware isn't getting downloaded?
Is an FTDI programmer necessary or I can directly connect the Rx, Tx and Gnd pins to the TX, RX and Gnd pins of the DB9 and flash the firmware?
Thanks,
Tanmay
Vcc 3.3V
CH-PD 3.3V
RST floating
GPIO1 Gnd
GND Gnd
GPIO2 floating
Thanks,
Tanmay
