As I am on MacOS X, I had to hack Arduino 1.6.1 IDE to work with pyesptool instead of the built-in esptool. GPI02 is connected to +3.3V by default.
This is what I have attempted:
- With GPIO0 to GND (so called UART mode, check: https://goo.gl/238T0F ).
I managed to flash the board only once, and this has been pretty much it.
I get the following error when trying to reprogram the board:
Connecting...
Traceback (most recent call last):
File "./esptool.py", line 479, in <module>
esp.connect()
File "./esptool.py", line 157, in connect
raise Exception('Failed to connect')
Exception: Failed to connectI get the green light flashing on the board - so I am guessing that something is happening.
I have also tried on a PC, without much luck.
- With GPIO0 to +3.3V (High):
The Blink program runs fine.
I am unable to connect via a serial connection in either mode, I have used 'screen' and 'CoolTerm'. I am not even getting garbage printed.
I sense that I probably wipe the board clean of any firmware other than the blink code, and that I am unable to trigger a serial connection on the board.
Any hints?
TIA
