As far as I know:
01:
- RX - serial-read pin, if not connected tie to ground? Can be used as an IO pin (https://github.com/eadf/esp8266_stdout)
GPIO0 - (10k) pullup for startup, pull high at reset for programming mode, otherwise use as GPIO
GPIO2 - (10k) pullup for startup, pull high at reset for programming mode, otherwise use as GPIO
GND - Gnd
VCC - 3.3V!, 100nF decoupling ceramic cap near the pin to Gnd
RST - (10k) pullup + switch to gnd for a restart (is there also a cap to gnd needed?)
CH_PD - (10k) pullup
TX - serial-write pin, if not connected tie to ground?
Did I miss something here? Is 10k the right value, or is there any reason to use another for the pullups? Here http://www.esp8266.com/viewtopic.php?f=13&t=3119 we discussed if gpio 0 and 2 can somehow be pulled low while still starting the esp... no real result yet. Does anyone know?
12:
- - VCC, Gnd, CH_PD, GPIO2, GPIO0, RX, TX stays the same
- GPIO15 (10k) pulldown at startup, afterwards normal GPIO?
- GPIO16 and RST directly connected to be able to use sleep mode?
- nRST (10k) pulldown
- ADC pins?
- GPIO4,5,12,13,14,16 are just gpios (if not used tie to Gnd?)
I would be thankful for every error here that you guys correct
Thanks
