- Tue Jun 02, 2015 12:45 am
#19184
Thank you for the answer
I'm using the ESP-01.
The ground was common when I tried to connect it the first time.
I tried to use external power source and it solved the original problem - now I can see the serial port and communicate with the ESP! (I know that powering the ESP from USB is problematic, though its weird that when I try to power arduino+ESP it works fine but FTDI+ESP doesn't...)
But there is a new problem: When I'm trying to restart the ESP using the AT+RST command, the device goes off and comes back to life only when I disconnect and reconnect it to the power source and FTDI. Further more, when the ESP is on, I cant connect to access points and the ESP access point does not exists. everything is very unstable, and when I try the same thing twice I might get different results.
Here is the message I get after trying to restart the ESP:
Code: Select allAT+RST
OK
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 816, room 16
tail 0
chksum 0x8d
load 0x3ffe8000, len 788, room 8
tail 12
chksum 0xcf
ho 0 tail 12 room 4
load 0x3ffe8314, len 288, room 12
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
Fatal exception (0):
epc1=0x4020c9a0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Any help would be much appreciated.
GG
EDIT: I found that some people had similar issues due to power supply problems. I'm using the YwRobot MB-102, that should give up to 700 mA. Anyone here had used it before?
Another thing that I found is that when the ESP is still cool (low temprature) it works fine and after about a minute of working it gets to hot and all the unstable fenomena begins... Is it normal for the ESP and the power supply board to get quite hot after a minute work?
EDIT 2:Well, turns out that the temprature is the problem. I found that if I direct a fan on the system it keeps it cool and everything works perfect. So now the question is why is the system gets too hot? had anyone had a simillar problem before?
EDIT 3 (and hopefully last for this thread)I think problem is solved
The fualt was in the power suplly. The 3.3 voltage regulator on the MB-102 was extremely over hitted. That was because I used 12V input to the board, and as I learned today on the hard way, too much voltage difference is not healthy. I changed the input to 3V - that was too low, and then to 4.5 V - and for now everything looks good
