I have made a code example from the SDK and compiled on windows, which reads a temp/hym. sensor and sends it to the internet.
It did work for a long time running on battery, then i added the ADC and measured the batt voltage, now the upload stops after short time ~ some hours.
I have set the upload time to 15min between and goes into deep sleep.
Normally it wakes correct, and also before the ADC was added.
Anyone there has a clue?
I recall the SDK to be 1.0.0 or 1.0.5.
I am litle unsure if i have to update the module itself when i flash directly from eclipse, will it then update the firmware in the module?
And also what is the difference in the different flash option ~ Flash file ~ Flash all etc.?
BR
Kasper
