Pictures
Pictures
Explore... Chat... Share...
Sjaak wrote:The chip antennas work worse then the PCB, which I didn't expected. ALthough it wasn't measured too scientificPerhaps some antenna guru's could shed a light on this?
Lars R. wrote:congrats for having a working board. PCB antenna being better than chip antenna is OK.
For measurements you might want to take the following into consideration:
http://en.wikipedia.org/wiki/Radiation_pattern
http://de.wikipedia.org/wiki/Richtcharakteristik
and
http://en.wikipedia.org/wiki/Polarization_%28waves%29
Have a look on how they measure here: http://www.ti.com/lit/an/swra351a/swra351a.pdf (click on links to see measurements for each antenna).
Not expecting such details here but maybe this helps.
Edit:
Do you think that connecting the RESET pin is required or could it be floating due to internal pullup and due to not being required for programming?
