I have doubts about ESP12E module - whether there are additional pins exist
Does anyone have a circuit diagram ESP12E ?
(ESP12 scheme'm also interested in)
Mariusz
Explore... Chat... Share...
Pad MTDO -> pin 20 SD_CMD
Pad MTDI -> pin 22 SD_DATA_0
Pad SD_3 -> pin 19 SD_DATA_3
Pad MTMS -> pin 21 SD_CLK
Pad MTCK -> pin 23 SD_DATA_1
Pad SD_2 -> pin 18 SD_DATA_2It takes about 20-25 seconds for home assistant c[…]
