At first, let me say that i am starting with this module. I´ve seen that the standard resistor values to communicate the ESP8266 with a serial module are 10k. Can I change those values? I have some 6.7 k resistors, can I use it?
Thanks,
A.
Explore... Chat... Share...
tytower wrote:anything down to about 4R7
