To start the ball rolling, here is mine:
I have an MB102 power supply that can take input from a wall wart or a USB. It is switched to 3.3V. I use ESP-12s that are plugged into female sockets on the breakout board. If I fry my ESP-12, I can plug in a new one quickly.
There are two sets 8-socket female sockets for plugging in breadboard links.
On the bottom left is a reset switch.
On the bottom right is a jumper that brings GPIO0 to GND or +ve.
At the top right is a second jumper that connects REST to DSR on the USB->UART used for flashing.
The 2nd USB->UART is used for debugging.
I didn't spend any time on layout management but space wasn't a consideration for my needs. Things that I would add on a second iteration (or a modification of this one) would be:
- sockets for an ESP-1
- LEDs with current limiting resistors with sockets
- Perhaps switches instead of jumpers
If you have the inclination, post your setups and lets see if we can find patterns or tricks we can share with each other.
Neil
