I am trying to control a vibration motor with the esp8266-01 but if I connect it and power up the esp it doesn't work and spits out garbage
Bram
Explore... Chat... Share...
bram wrote:Hey,
I am trying to control a vibration motor with the esp8266-01 but if I connect it and power up the esp it doesn't work and spits out garbage. I directly connected the motor to the esp but also tried a transistor and it had the same effect. Directly connecting to the esp8266-03 did work
put not to my esp8266-01
. Does anyone have suggestions?
