If there's any interest, I can also add a reset button (that would work by disconnecting power while pressed) and some DIP switches to put the chip in firmware flashing mode.
Explore... Chat... Share...
alonewolfx2 wrote:its good. you can add reset and firmware mode switches.
i think ams1117 wrong choise for low power operation. it consume 2-3ma on iddle mode. maybe you can change ams1117 with ldo(low drop voltage regulator)
I'd also recommend not soldering the power LED on.
MIC5219-3.3
