Problem exiting from socket connection
PostPosted: Thu Oct 29, 2015 5:50 am
by Sunny
Hi there,
I'm a newbie to LUA and ESP8266. I've written below code to create a socket, read the date & time from a server, convert format and store in a global variable dateRcv. The code ran ok to get date and time. However, it can never return from the function gettime() that created the socket. If I add timer loop after gettime() is called, the program seemed to have crashed and exit.
Can someone helped me and pointed me to the right direction? Many thanks!
Code: Select allportno = 13
tcpserverip = "ptbtime2.ptb.de"  -- "ptbtime1.ptb.de"
SSID = "TEST"
pwd = "1234abcd"
dateRcv = ""
starttime = tmr.time()
wifi.setmode(wifi.STATION)
wifi.sta.config(SSID,pwd)
wifi.sta.connect()
repeat
    tmr.alarm(0, 1000, 0, function() end)
    print("Get IP address status: ", wifi.sta.status())
until wifi.sta.status() >= 2
if wifi.sta.status() >=2 then
    net.dns.setdnsserver("58.176.125.223",0)
    print("DNS server: ", net.dns.getdnsserver(0))
end
function gettime(port, TSip)
    local mt = {JAN=1,FEB=2,MAR=3,APR=4,MAY=5,JUN=6,JUL=7,AUG=8,SEP=9,OCT=10,NOV=11,DEC=12}
    local time = ""
    local gotdate = false
    if (wifi.sta.getip() ~= nil) then
        sk = net.createConnection(net.TCP, 0)
        sk:on("receive", function(sk, payload)
            print("Received data "..payload)
            m = (mt[string.sub(payload, 4, 6)])
            dateRcv = string.sub(payload, 10,11) .. "-"..m .."-".. string.sub(payload, 1, 2)
            time = string.sub(payload, 13, 20)
            print("Date, time: ", dateRcv, time, "\n")
            gotdate = true
            sk:close()
        end)
        sk:connect(portno, tcpserverip)
        sk:on("connection",function(sk, payload)
              sk:send(" ")
        end)
        sk:on("disconnection",function(sk)
            sk=nil
            print("Disconnecting...")
            collectgarbage()
        end )
    else
        print("Failed to connect. Stopped retry!")
    end
  return
end
gettime(portno, tcpserverip)
--[[  remove below comment block will allow function to exit but
      dateRcv can't be retrived.
repeat
until dateRcv ~= ""
print("Date Received: ", dateRcv)
Output:
Get IP address status: 5
DNS server: 58.176.125.223
> Received data 29 OCT 2015 10:48:23 UTC
Date, time: 15-10-29 10:48:23
Disconnecting...
Re: Problem exiting from socket connection
PostPosted: Sun Nov 01, 2015 4:07 am
by Sunny
Sunny wrote:Hi there,
SSID = "TEST"
pwd = "1234abcd"
dateRcv = ""
wifi.sta.connect()
repeat
end
    local time = ""
            gotdate = true
            sk:close()
        end)
              sk:send(" ")
        end)
            sk=nil
            collectgarbage()
        end )
    else
    end
  return
end
repeat
until dateRcv ~= ""
Output:
Disconnecting...
Hi there,
I've my problem fixed. I changed the repeat loop with the tmr.alarm to a the repeat mode. The gettime function is called only when wifi.sta.getip() ~= nil. Other functions are then triggered by the "receive" event. With that, the program runs ok.
Unfortunately, when I tried to add in other functionalities, the LUA compiler flags not enough memory. I might have stretched the nodemcu capability too much. So I have decided to move to the ESP8266 SDK and develop under "C".
Thanks!
Sunny
