Page 1 of 2
Serial communication works only one way
PostPosted: Tue Dec 02, 2014 11:47 am
by viktak
Hi Guys,
I just received my ESP8266 module, the one with the 2*4 pin header on the side. I am also using a CP2102 based USB-serial dongle. Supplying the 3.3V from a separate power module.
When I power it up I can see the following message in Putty (9600bps 8N1):
Code: Select all[Vendor:www.ai-thinker.com Version:0.9.2.4]
ready
This tells me that the serial communication is set up correctly. (Right?)
The wifi part is also, OK, I can connect to the wifi network it creates.
BUT: it doesn't respond to any AT command I send to it. The blue LED flashes as I type in the terminal window (Putty), but it wouldn't respond to it when I press Enter.
Any idea what could be wrong? Could it be a faulty module? Do I miss some special setting in Putty?
Any pointers are appreciated!!!
Re: Serial communication works only one way
PostPosted: Tue Dec 02, 2014 12:05 pm
by alonewolfx2
Most likely you have iot firmware on your esp. (it can't respond any at command) you must to flash at firmware.
PostPosted: Tue Dec 02, 2014 12:23 pm
by viktak
Thanks for the quick reply!
Can you point me to a specific firmware I could try?
Cheers!
PostPosted: Tue Dec 02, 2014 12:27 pm
by martinayotte
It's also possible that your Putty is configured as CR only where latest AT firmware requires CRLF on every request
