Barnabybear wrote:https://github.com/marcoschwartz/aREST/blob/master/aREST.h
Lines 750 & 751.Code: Select all// Apply on the pin
digitalWrite(pin,value);
Change to.Code: Select all// Apply on the pin
digitalWrite(pin,High); // sets output pin high to simulate button press.
delay(1000); // delay for length of button press.
digitalWrite(pin,LOW); // sets output pin bak to low to end button press.
I have this setup on GPIO2 so to opperate I can go to ESP IP (192.168.1.xx) and press the button or
go to ESP IP and attach the command (192.168.1.xx/digital/2/1)
format < ESP IP address > / < type of operation (digital write) > / < GPIO to affect (2) > / < effect ( set as 1) >
Mine has just started to hang sometimes (reset fixes it) I'll look into it later.
not sure whats wrong, but after i make those changes to arest.h there is an error compiling, maybe there is also another step you forgot to tell me?
Arduino: 1.6.5 (Windows 8.1), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, 115200"
In file included from ESP8266.ino:5:0:
C:\Users\Isaac\Documents\Arduino\libraries\aREST-master/aREST.h: In member function 'bool aREST::send_command(bool)':
C:\Users\Isaac\Documents\Arduino\libraries\aREST-master/aREST.h:745:25: error: 'High' was not declared in this scope
In file included from ESP8266.ino:6:0:
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h: In member function 'virtual void aREST_UI::root_answer()':
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:71:69: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:72:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<html><head>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:73:91: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:74:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<script ");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:75:70: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("src=\"http://code.jquery.com/jquery-2.1.3.min.js\">");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:76:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("</script>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:77:118: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<script type='text/javascript' src='http://cdn.rawgit.com/Foliotek/AjaxQ/master/ajaxq.js'></script>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:78:112: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<style>.row {margin-top: 30px;} .indicator {font-size: 30px; vertical-align: middle;}</style>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:79:123: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<link rel=\"stylesheet\" href=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/css/bootstrap.min.css\">");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:80:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("</head><body>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:81:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class=\"container\">");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:85:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<h1>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:87:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("</h1>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:90:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<h1>Interface</h1>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:95:40: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class=\"row\">");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:96:106: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class=\"col-md-2\"><button class=\"btn btn-block btn-lg btn-primary\" id='btn_on");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:98:40: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("'>On</button></div>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:99:106: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class=\"col-md-2\"><button class=\"btn btn-block btn-lg btn-danger\" id='btn_off");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:101:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("'>Off</button></div>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:102:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("</div>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:107:40: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:109:113: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class=\"col-md-2\"><input type='range' value='0' max='1023' min='0' step='5' id='slider");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:114:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("'></div>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:115:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:120:40: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:121:53: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class='col-md-3 indicator'>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:123:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer(": </div>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:124:57: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<div class='col-md-3 indicator' id='");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:126:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:127:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:130:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:132:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("<script>$( document ).ready(function() {");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:136:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("$('#btn_on");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:138:67: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("').click(function() {$.getq('queue','/digital/");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:140:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("/1');});");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:141:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("$('#btn_off");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:143:67: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:145:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("/0');});");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:150:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("$('#slider");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:152:64: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("').mouseup(function() {var val = $('#slider");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:154:55: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("').val(); $.getq('queue','/analog/");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:156:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("/' + val); });");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:161:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("$.getq('queue','/");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:163:45: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("', function(data) { $('#");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:165:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("').html(data.");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:167:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("); });");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:170:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("});</script>");
C:\Users\Isaac\Documents\Arduino\libraries\aREST_UI-master/aREST_UI.h:172:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
addToBuffer("</body></html>\r\n");
ESP8266.ino: In function 'void setup()':
ESP8266.ino:30:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
ESP8266.ino:31:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
