This is one of my first projects, so am still learning
Ok, so I've got a 3V doorbell (Friedland D902), which apparently should take 200mA (they are not very clear on this though). When I power my NodeMCU (it's the LoLin "v3"-version with a 1777 voltage regulator) of a USB 2.0-port and connect the bell to the 3V and GND on the ESP, success!
However.. when I add a pull-up resistor and low-pass filter to the D1 (to take not of the doorbell button), there seems to be no enough juice left for the bell. The result is a moving bell hammer, but not hard enough to make it ring.
The D1 gets input from the doorbell-button from about a meter of two of wire (hence the filter).
Like this: DOORBELL BUTTON (long wire) - 100ohm -then from there splits -> 100K pull up to +3.3V and -> 0.1 uF to NEG, and the wire finishes on D1 (hope that's a clear enough description).
So on this set-up (that works quite well filtering out radiation false positives), the 3.3V doesn't seem to provide enough amps to power the bell anymore (eventually I'd run this through a relay, but even connecting straight to the bell now isn't powerfull enough anymore)... Isn't that odd? - Thought that a pull-up wouldn't take a whole lot of power..
Any suggestions anyone?
