Won't operate on power source other than USB connected to PC
Posted: Fri Dec 11, 2015 9:23 pm
I recently purchased a Node MCU 1.0 board and have been playing with it the last couple of days. I have it up and running and everything seems fine, but I cannot get it to work on any power source other than a USB cable connected to a PC. I have tried supplying 5V to the VIN pin both with and without also supplying 3.3V to one of the respective pins, and I have also used a USB cord plugged into a power adapter to supply 5V through the USB port without being connected to a PC. The only behavior I get with all of those methods is that the blue LED by the WiFi antenna flashes briefly and D0 and D4 go high (I have LEDs on D0-D7). The board will only execute its stored program if powered by a USB cable connected to a PC. This is crazy. I have to be overlooking something simple... I hope.
