Hello guys,
I also just received a WeMos D1 Mini board yesterday. My first impressions were positive. It looks pretty good for how cheap it is. It has all the features I was looking for in an ESP8266 board and took a while to come across. I'm using Arduino IDE to program. Started some tutorials: Hello world, blink the onboard LED (btw the pinouts are different, here's a link that helps
http://www.wemos.cc/wiki/doku.php?id=en:d1_mini), and got some WiFi stuff going really fast and easily!
The first WiFi tutorial I used was the Sparkfun Thing tutorial, where I set up the WeMos as an access point, to which I connected with my iphone and sent/received data. The signal worked all throughout the house and the speed was nearly instantaneous. Next, I did the Adafruit tutorial and accessed the web with the WeMos. After that, I tried out Over the Air (OTA) downloads using the ESP8266 example OTABasic from Github. It worked like a charm. I then disconnected the WeMos from the computer and used a USB battery and it worked great.
Today, I wanted to try out some hardware with the WeMos. First, I soldered some header pins to the board and stuck it on a breadboard. Then I hooked up a servo (MG 996R High Torque) using an external power source. The WeMos outputs a 3.3V signal, but the servo datasheet says it take a 4.8V to 7.2V signal. So I was curious if it would work. I ran the example Sweep and... it worked... kind of. The servo rotated like it should, but was a little jumpy and wasn't when I used a 5V Arduino running the same sketch. So I might need to use a level shifter. The next thing I did was test running the Servo's power off of the WeMos's 5V pwr pin. With the same sketch stored, I hooked the WeMos to a 2A USB battery and then plugged the servo into the WeMos.
Immediately, the WeMos started smoking!!!!!!Unfortunately, that was too much current draw. The servo datasheet says it runs 500-900mA at 6V and up to 2.5A stalled. I was really hoping it would work. Can't seem to find any specs on the max output of the WeMos.
I think the next thing I will do is test using a level shifter and external power supply, and then measurethe current draw of the servo.
