While setting GPIO0 to ground shorts VCC (and CH_PD) and GND - and hangs raspberry pi. I have checked continuity before and after grounding GPIO0 and checked before/after VCC.
What causes this behavior? Any help would be appreciated. Thanks.
Explore... Chat... Share...
