Help!! NodeMCU Lua v1 Capacitive touch sensor
Posted: Sun Feb 07, 2016 1:23 am
Hi im working with iot and i want to use capacitive sensor but when i use it its display unknown thing on serial monitor Someone PLZ help!!!
THIS IS CODE.
AND THIS IS OUT PUT.
THIS IS CODE.
#include <CapacitiveSensor.h>
CapacitiveSensor cs_7_4 = CapacitiveSensor(D7,D4); // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired
CapacitiveSensor cs_7_3 = CapacitiveSensor(D7,D3); // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
CapacitiveSensor cs_7_2 = CapacitiveSensor(D7,D2); // 10M resistor between pins 4 & 8, pin 8 is sensor pin, add a wire and or foil
void setup()
cs_7_4.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
Serial.begin(9600);
void loop()
long start = millis();
long total1 = cs_7_4.capacitiveSensor(30);
long total2 = cs_7_3.capacitiveSensor(30);
long total3 = cs_7_2.capacitiveSensor(30);
Serial.print(millis() - start); // check on performance in milliseconds
Serial.print("\t"); // tab character for debug windown spacing
Serial.print(total1); // print sensor output 1
Serial.print("\t");
Serial.print(total2); // print sensor output 2
Serial.print("\t");
Serial.println(total3); // print sensor output 3
delay(10); // arbitrary delay to limit data to serial port
