AdrianM wrote:You're not going to like this but from RFP30N06LE datasheet
1) Absolute Maximum continuous drain current 30A (not 33A)
2) Even with 5V on Gate, at 30A, RdsOn=0.047R
SO using nothing more than Ohms Law, Vds =30A x 0.0.47R = 1.41V
Power=VxI = 1.41x30 = 42.3Watts = smoke + molten mess
With a 1'C/W heatsink you might get away with it but with a 3.3V Gate drive even this huge chunk of Aluminium won't be enough.
Also, what PSU, cable and connectors are you planning on using
again your are giving me a big advise and in same time broke my dreams
summery is that i shouldn't go far in Amps , for that do you think is should divide the LED strip in enough length that will be in safe Amps power consumption to drive with a MOSFET- still not selected- and use my Software power by make my boards listing to the same MQTT so they will act together as one maybe with small acceptable delay of some ms.
and the highest Power supply i found that can give up to 50A is this one @ $40
so any suggestion which MOSFET i should use to 3.3V signal from ESP8266 to drive 10 meter LED strip (almost 20 A/3 ≃ 7) without the need of heatsink and package can be TO-220
