i plan to create a small development board for the ESP-07. Originally i wanted to use the ESP-01 version but it doesn't have any ADC pins brought to the surface.
So i guess i will stick to the ESP-07. I created a schematic in eagle. The pcb will act as a kind of development board. I use a micro-usb port as power source. The 5V input will be converted to 3.3V by the LM1117. I then use 2 jumper 1x2-pinheads to set the ESP8266 into flashing mode:
But i have 3 questions now:
1. Do i need the 10k resistor to pull the CH_PD pin high? If so, do i need one for the GPIO02 pin as well?
2. The pin labeling in eagle differs from the one found on aliexpress: http://de.aliexpress.com/item/ESP8266-s ... 03471.html Which one is trust worthy?
3. Is it the right way to use 2 1x2 pinhead as jumpers?
