ESP-01 RX pin voltage
Posted: Sat Apr 02, 2016 5:01 pm
I had read that I should use a bi-directional level converter board so that I can use the ESP8266 with the Arduino Uno R3, so I bought a few on eBay. http://i.ebayimg.com/images/g/yD8AAOSwpDdVRM9R/s-l1600.jpg
I am currently using an Arduino Uno as a USB-serial converter; the Atmega microcontroller has been removed per tutorial http://rancidbacon.com/files/kiwicon8/ESP8266_WiFi_Module_Quick_Start_Guide_v_1.0.4.pdf
I have a separate 3.3V power supply.
I have found that if I use the level converter board for the RX pin, then I get no communication. Yet if I connect the RX pin on the ESP-01 directly to the Arduino RX pin, then I get communication.
The TX pin works fine with the level converter board.
Can anyone tell me why this is happening?
