Flash new firmware into ESP-01 8Mbit flash
Posted: Mon May 09, 2016 11:49 am
I have problems flashing new firmware into ESP-01 with 8Mbit (1Mbyte) flash. I order the module here http://pt.aliexpress.com/item/Free-ship ... 07007.html On the picture you can see "AL1510" flash chip, but on the actual module I got there are "Berg Micro 25Q80A" flash chips installed.
So when I try to flash new firmware the chip cannot boot. I tried to flash it with esptool.py, NodeMCU Flasher and the official flashtool from espressif. When I plug in my USB to UART TTL converter after flashing it immediately disconnects and no COM port is available for connection. I tried several combinations of configuration for the flasher software like lowering the SPI clock rate, changing crystal frequency and changing flash mode (DIO, QIO, ...) Nothing worked.
Maybe I am missing something basic?
