boot_v1.2+.bin 0x00000
user1.1024.new.2.bin 0x01000
blank.bin 0x7e000 & 0xfe000and the module start but the doesn't connect or gives ip to other devices.
After that i noticed that the flash tool sees only 4Mbit so i used these other addresses:
eagle.flash.bin 0x00000
eagle.irom0text.bin 0x40000
blank.bin 0x3e000 & 0x7e000That i found in a readme file.
Now the module start, accept the command but like before is not able to connect to a router or able to give ip address.
The firmware is correctly flashed since AT+GMR gives
AT version:0.30.0.0(Jul 3 2015 19:35:49)
SDK version:1.2.0
compile time:Jul 3 2015 20:52:41The only strange things that is that during soft reset there is fail in the memory check
AT+RST
OK
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 26444, room 16
tail 12
chksum 0xe3
ho 0 tail 12 room 4
load 0x3ffe8000, len 1404, room 12
tail 0
chksum 0xd0
load 0x3ffe8580, len 4436, room 8
tail 12
chksum 0x2a
csum 0x2a
ŒÂÕ�MEM CHECK FAIL!!!
ärlŽ‚rô
readyNow i don't know where is my mistake. Can someone tell me what can i do.
Thanks
