happy new year!
i work at spi and mcp23s17 so i make for esp8266 a base for my playing.
here
used:
ESP8266 ESP-12 AI-THINKER
MCP23S17 MICROCHIP
LED Array NO NAME
in this short video i show the new ESP-12 from ai-thinker with adc and all gpio and append in function i will show you here my new firmware with spi and portexpansion by using the MCP23S17
i installed a spi portexpander from microchip MCP23S17 for gives the esp8266 2 full port more.
portA with 8 GPIO as setup here as Output
portB with 8 GPIO reserve
for demontstration i connect from portA 8 GPIO's to a LED array and run
a simple small base firmware for fun.
you can connect from same SPI Expansion device 8 devices
the devices are called by the device adress so you must take for each device a separatly CS.
you can set this with 3 port adress A2 A1 A0
in this demo i set all to GND and the device is device ID : 0
A2=0 A1=0 A0=0 Device ID is : 0
A2=0 A1=0 A0=1 Device ID is : 1
A2=0 A1=1 A0=1 Device ID is : 2
A2=0 A1=1 A0=0 Device ID is : 3
A2=1 A1=0 A0=0 Device ID is : 4
A2=1 A1=0 A0=1 Device ID is : 5
A2=1 A1=1 A0=0 Device ID is : 6
A2=1 A1=1 A0=1 Device ID is : 7
you can connect a LCD to the SPI Expander and any more.
you can connect a second to portB or more..
If you set the ports as Input you can make a 64 switch
with 8 devices you will have many possible's
have fun and thanks for watching!
best wishes
rudi
