I've used the esp-01 and Arduino Nano to control an Electric door and a Water heater from internet, using the Thinger platform. The Android application is used to turn ON/OFF the Water heater and to hold open the Electric door for 2 seconds.
This can be done with esp-01 itself and 2 transistors, without Arduino, but I'm planing to upgrade the project and add 2 more devices on it using RF 433mhz modules to communicate to the other room.
Components used
- Arduino Nano
esp8266 wifi module
2 channel relay
1 channel relay
400 point breadboard
breadboard power supply
esp8266 code
First I've created a device called "wifi" on Thinger and then uploaded the code to the esp-01:
bojler = water heater
vrata = electric door
#include <SPI.h>
#include <ThingerWifi.h>
#define USERNAME "username"
#define DEVICE_ID "deviceid"
#define DEVICE_CREDENTIAL "devicecredentials"
#define SSID "networkName"
#define SSID_PASSWORD "networkPassword"
ThingerWifi thing(USERNAME, DEVICE_ID, DEVICE_CREDENTIAL);
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
thing.add_wifi(SSID, SSID_PASSWORD);
// resource input example (i.e. turning on/off a light, a relay, configuring a parameter, etc)
thing["bojler"] << [](pson& in){ digitalWrite(0, in ? HIGH : LOW); };
thing["vrata"] << [](pson& in){ digitalWrite(2, in ? HIGH : LOW); };
thing.handle();
Arduino code
then uploaded the code to the Arduino:
int bojler = 2;
int vrata = 3;
int sostojba = 0;
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
pinMode(bojler, OUTPUT);
pinMode(vrata, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(vrata, LOW);
int pom1 = analogRead(A0);
int pom2 = analogRead(A1);
float bojlerV = pom1 * (5.0 / 1023.0);
float vrataV = pom2 * (5.0 / 1023.0);
if (bojlerV<2)
digitalWrite(bojler, HIGH);
else if (bojlerV>3)
digitalWrite(bojler, LOW);
if (vrataV<2)
sostojba = 0;
else if (vrataV>3)
sostojba++;
if (sostojba==10)
sostojba = 2;
if (sostojba==1)
digitalWrite(vrata, HIGH);
delay(2000);
delay(250);
Serial.print("Bojler napon: ");
Serial.println(bojlerV);
Serial.print("Vrata napon: ");
Serial.println(vrataV);
Serial.print("Sostojba: ");
Serial.println(sostojba);
And the wiring looks like this
