Questions with regards to ESP8266 Basic and hardware interfacing and control via Basic commands
By forlotto
#51241 Why not I figured I would include some info about the esp8266 itself and where everything is located in address space I will warn this was copy/paste info. But good to have in the hardware section.
Kind of useful if someone were going to try and disassemble the thing or create an emulator or simulator that would allow you to see instructions being made and some of this allow user input in cmd/resp format so you can see what is happening at machine level or even pause things or slow them down etc I've seen this before but this is normally more of an assembly based thing while not related to basic directly it is related indirectly so might be useful for those on the search.
Code: Select all0x00000000   ****      Exc      Protected area
0x20000000   ****       ---      Unmapped, repeated pattern
0x3FF00000   0x010000   R/W      Memory-mapped I/O, repeated every 0x100.
0x3FF10000   0x010000   R only   Mapped, zeroes
0x3FF20000   0x001800   R/W      I/O registers
0x3FF21800   0x09E800   R only   Mapped, zeroes
0x3FFC0000   0x020000    ---      Unmapped, repeated pattern
0x3FFE0000   0x008000   R only   Mapped, zeroes
0x3FFE8000   0x014000   R/W      User data RAM. Available to applications.
0x3FFFC000   0x004000   R/W      ETS system data RAM.
0x40000000   0x010000   R only   Internal ROM.
0x40010000   0x010000   R only   Internal ROM (repeated 0x40000000).
0x40020000   0x0E0000   R only   Mapped, zeroes
0x40100000   0x008000   R/W      RAM
0x40108000   0x038000   R only   Mapped, zeroes
0x40140000   0x0C0000   ---      Unmapped, repeated pattern
0x40200000   0x100000   R only   SPI Flash is mapped (512k->2x repeated, 16Mb - 1Mb mapped )
0x40300000   ****       ---      Unmapped, repeated pattern
0x60000000   0x001000   R/W           I/O registers
0x60001000   0x000400   R/W      RAM
0x60001400   0x000400   R/W           I/O registers
0x60001800   0x000400   R/W      RAM (repead 0x60001000)
0x60001C00   0x000400   R/W           I/O registers (repeated 0x60001400)
By martinayotte
#51263 For peope interested with low level, in the ArduinoESP framework, this file provide lot of registers details :
esp8266/2.3.0/cores/esp8266/esp8266_peri.h
By forlotto
#51310 excellent thanks for sharing!
