Page 1 of 3
is it possible to make ESP8266 Module as a USB WiFi Adapter?
PostPosted: Sat May 27, 2017 3:39 pm
by Tito781227
I have this WiFi module called ESP8266 Nodemcu Module
Picture:
You can see that we use the micro usb input in the module to give it Power and Also to program it with Arduino
However,
i looked in the examples in Arduino IDE about ESP8266,
i also googled about it,
i couldn't find anything related to giving internet through that micro usb input,
what i mean is, i want this Module to connect to my home WiFi Router, and give internet to my PC Through USB!
Short Question: is it possible to make ESP8266 Nodemcu Module as a USB WiFi Adapter?
Is there any code or a firmware to achieve this?
Any ideas would be appreciated..
Re: is it possible to make ESP8266 Module as a USB WiFi Adap
PostPosted: Mon May 29, 2017 7:45 am
by martinayotte
The USB is only a Serial port ...
PostPosted: Tue May 30, 2017 1:26 pm
by Robot Hacker
martinayotte wrote:The USB is only a Serial port ...
And modems connect through a serial port. So, Yes, it can be made into a WiFi adapter. :D
I have not seen it done yet, but that does not mean that it has not been done. I have not looked for it.
PostPosted: Tue May 30, 2017 3:03 pm
by martinayotte
Waste of time ... If an USB adaptor is needed, I would rather continue using Realtek or Ralink USB dongles.
(Espcially that throughput is about 100 times faster then what can be done over serial.)
