I'm using the esp8266 Luncher, compiling C code with the RTOS SDK V2.0.0 and flashing the code with esptool.py.
After flashing the spiffs_test exemple, at boot, the chip now enter a panic loop. I tried flashing an other code but it's all the same. Using esptool.py, I have erased the flash and used the ESP8266 DOWNLOAD TOOL v3.6.3 to flash the esp_init_data_default.bin.
Doing this I have noticed something. When flash the esp init, I get a different message rather if I then upload a code or not.
without flashing anything but the esp_init thing:
ets Jan 8 2013,rst cause:1, boot mode:(3,2)
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 16Mbit(1024KB+1024KB)
jump to run user1 @ 1000
rf_cal[0] !=0x05,is 0xFFafter flashing a code of mine:
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 128Mbit(1024KB+1024KB)
OS SDK ver: 2.0.0(e271380) compiled @ Mar 30 2018 18:54:06
rf_cal[0] !=0x05,is 0xFFDo you kow how could end this and return to a factory deflaut ?
thank you ♥
