I am in real need to get live debugging data while my program runs, but can only do throught UART0, it doesn't come through UART1 when I configure it to do so.
This is my uart init so it does dump the os_printfs on UART1:
void ICACHE_FLASH_ATTR
uart_init(UartBautRate uart0_br, UartBautRate uart1_br, DataRxCb aRxCb)
// Record callback to push out uart0 data
rxCb = aRxCb;
/*this is a example to process uart data from task,please change the priority to fit your application task if exists*/
system_os_task(uart_recvTask, uart_recvTaskPrio, uart_recvTaskQueue, uart_recvTaskQueueLen); //demo with a task to process the uart data
UartDev.baut_rate = uart0_br;
uart_config(UART0);
UartDev.baut_rate = uart1_br;
uart_config(UART1);
ETS_UART_INTR_ENABLE();
#if UART_BUFF_EN
pTxBuffer = Uart_Buf_Init(UART_TX_BUFFER_SIZE);
pRxBuffer = Uart_Buf_Init(UART_RX_BUFFER_SIZE);
#endif
system_set_os_print(1);
os_install_putc1((void *)uart1_write_char); //use this one to output debug information via uart1 //
/*option 1: use default print, output from uart0 , will wait some time if fifo is full */
//do nothing...
/*option 2: output from uart1,uart1 output will not wait , just for output debug info */
/*os_printf output uart data via uart1(GPIO2)*/
//os_install_putc1((void *)uart1_write_char); //use this one to output debug information via uart1 //
/*option 3: output from uart0 will skip current byte if fifo is full now... */
/*see uart0_write_char_no_wait:you can output via a buffer or output directly */
/*os_printf output uart data via uart0 or uart buffer*/
//os_install_putc1((void *)uart0_write_char_no_wait); //use this to print via uart0
#if UART_SELFTEST&UART_BUFF_EN
os_timer_disarm(&buff_timer_t);
os_timer_setfn(&buff_timer_t, uart_test_rx, NULL); //a demo to process the data in uart rx buffer
os_timer_arm(&buff_timer_t,10,1);
#endif
All I ever get on UART1 is the below when the program crashes:
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x40100000, len 28436, room 16
tail 4
chksum 0xf8
load 0x3ffe8000, len 2508, room 4
tail 8
chksum 0x90
load 0x3ffe89d0, len 17372, room 0
tail 12
chksum 0xb3
csum 0xb3
I would be really greatefull if someone would point out what might be the problem.
Thanks in advance
