[../library/webserver.h][WebServerConn_recv_callback][468]
Sending Config[../library/webserver.h][WebServerConn_connect_callback][441] - Client connected
[../library/webserver.h][HttpSendWithHeader][21] - Freeheap 12592 vs. 12592
HTTP Response sent bytes: 4885
scandone
[../library/webserver.h][HTMLConfigscan_done][38]
Heap allocated for SSID's: 2048 Freeheap: 15568
Heap allocated for SSID's left: 1968 Freeheap: 15568
(3,"Rob Stone-2G",-96,"34:6b:46:2d:4c:86",6)
[../library/webserver.h][HttpSendWithHeader][21] - Freeheap 7368 vs. 7368
Unable to send, need a moment to breath to free memoryE:M 8200
Fatal exception 29(StoreProhibitedCause):
�pc1=0x4000e1b2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
load 0x3ffe8000, len 2192, room 16
tail 0
chksum 0x8c
load 0x3ffe8890, len 22144, room 8
tail 8
chksum 0x1c
load 0x40100000, len 30784, room 0
tail 0
chksum 0x13
csum 0x13
����n�r��n|�llll`b��|r�l�n��n�l`��r�l�l�l`��r�l�l�l`��r�l���ڹ./library/../library/common.h][Common_UserInit][1412]
sleep disable
Starting ESP8266 Standard!
SDK version:2.1.0(116b762)
Loaded from: 0x00
Vdd33_Const: ff
data : 0x3ffe8000 ~ 0x3ffe8890, len: 2192
rodata: 0x3ffe8890 ~ 0x3ffedf10, len: 22144
bss : 0x3ffedf10 ~ 0x3fff4a48, len: 27448
heap : 0x3fff4a48 ~ 0x3fffc000, len: 30136
reset reason: 2
REASON_EXCEPTION_RST (29)
[GetEXCCount]
GET GetEXCCount 1
[StoreEXCCount] creating with: 2
epc1=0x4000e1b2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
System halt!
I keep receiving the following exception, then I use this
[osboxes@osboxes Main]$ locate elf-objdump
/home/osboxes/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-objdump
[osboxes@osboxes Main]$ /home/osboxes/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-objdump -d Main.o -S --start-address=0x4000
Main.o: file format elf32-xtensa-le
Disassembly of section .irom0.text:
00004000 <init_ThermostatSettings+0xa0>:
4000: 000021 l32r a2, fffc4000 <user_init+0xfffb8e20>
4003: 000001 l32r a0, fffc4004 <user_init+0xfffb8e24>
4006: 0000c0 callx0 a0
4009: 000846 j 402e <init_ThermostatSettings+0xce>
400c: 280000 excw
400f: 0f .byte 0xf
4010: 0c1266 bnei a2, 1, 4020 <init_ThermostatSettings+0xc
0>
4013: 000021 l32r a2, fffc4014 <user_init+0xfffb8e34>
4016: 000001 l32r a0, fffc4018 <user_init+0xfffb8e38>
4019: 0000c0 callx0 a0
401c: 000386 j 402e <init_ThermostatSettings+0xce>
401f: 0f2800 excw
4022: 082266 bnei a2, 2, 402e <init_ThermostatSettings+0xc
e>
4025: 000021 l32r a2, fffc4028 <user_init+0xfffb8e48>
4028: 000001 l32r a0, fffc4028 <user_init+0xfffb8e48>
402b: 0000c0 callx0 a0
402e: 0f1d mov.n a1, a15
4030: b108 l32i.n a0, a1, 44
4032: a1f8 l32i.n a15, a1, 40
4034: 30c112 addi a1, a1, 48
4037: f00d ret.n
4039: 000000 ill
0000b1e0 <user_init>:
b1e0: f0c112 addi a1, a1, -16
b1e3: 3109 s32i.n a0, a1, 12
b1e5: 21f9 s32i.n a15, a1, 8
b1e7: 01fd mov.n a15, a1
b1e9: 020c movi.n a2, 0
b1eb: 000005 call0 b1ec <user_init+0xc>
b1ee: 020c movi.n a2, 0
b1f0: b6a232 movi a3, 0x2b6
b1f3: 000001 l32r a0, fffcb1f4 <user_init+0xfffc0014>
b1f6: 0000c0 callx0 a0
b1f9: 000005 call0 b1fc <user_init+0x1c>
b1fc: 000005 call0 b200 <user_init+0x20>
b1ff: 000021 l32r a2, fffcb200 <user_init+0xfffc0020>
b202: 000001 l32r a0, fffcb204 <user_init+0xfffc0024>
b205: 0000c0 callx0 a0
b208: 0f1d mov.n a1, a15
b20a: 3108 l32i.n a0, a1, 12
b20c: 21f8 l32i.n a15, a1, 8
b20e: 10c112 addi a1, a1, 16
b211: f00d ret.n
It seems that the address 0x4000e1b2 does not exist in Main.O as it ends on 0x4000b211... Anyone know any background details on how I can narrow down the root cause. Thank you!!
As for addtional detail, it seems in https://www.espressif.com/sites/default ... ses_en.pdf on page 3/4 that this may be more of a ROM issue?
Update: It seems that I found a feed of the obj dump on google.
memset:
4000e190: 743030 extui a3, a3, 0, 8
4000e193: 117380 slli a7, a3, 8
4000e196: 203370 or a3, a3, a7
4000e199: 117300 slli a7, a3, 16
4000e19c: 203370 or a3, a3, a7
4000e19f: 205220 or a5, a2, a2
4000e1a2: cee207 bbsi a2, 0, 4000e174 <memmove+0x128>
4000e1a5: d8e217 bbsi a2, 1, 4000e181 <memmove+0x135>
4000e1a8: 417440 srli a7, a4, 4
4000e1ab: 179c beqz.n a7, 4000e1c0 <memset+0x30>
4000e1ad: 1167c0 slli a6, a7, 4
4000e1b0: 665a add.n a6, a6, a5
4000e1b2: 0539 s32i.n a3, a5, 0
4000e1b4: 1539 s32i.n a3, a5, 4
4000e1b6: 2539 s32i.n a3, a5, 8
4000e1b8: 3539 s32i.n a3, a5, 12
4000e1ba: 10c552 addi a5, a5, 16
4000e1bd: f12567 blt a5, a6, 4000e1b2 <memset+0x22>
4000e1c0: 056437 bbci a4, 3, 4000e1c9 <memset+0x39>
4000e1c3: 0539 s32i.n a3, a5, 0
4000e1c5: 1539 s32i.n a3, a5, 4
4000e1c7: 558b addi.n a5, a5, 8
4000e1c9: 036427 bbci a4, 2, 4000e1d0 <memset+0x40>
4000e1cc: 0539 s32i.n a3, a5, 0
4000e1ce: 554b addi.n a5, a5, 4
4000e1d0: 046417 bbci a4, 1, 4000e1d8 <memset+0x48>
4000e1d3: 005532 s16i a3, a5, 0
4000e1d6: 552b addi.n a5, a5, 2
4000e1d8: 026407 bbci a4, 0, 4000e1de <memset+0x4e>
4000e1db: 004532 s8i a3, a5, 0
4000e1de: f00d ret.n
I think my program is crashing within a memset call.. Maybe one of my alloc's is sliently failing cauing memset in my userland code to trigger this exception?
https://0x04.net/~mwk/doc/xtensa.pdf <-- I then found this and looked up s32i.n and found this on page 78/662
Table 4–27. Code Density Option Instruction Additions
Instruction1 Format Definition
ADD.N RRRN Add two registers (same as ADD instruction but with a 16-bit encoding).
ADDI.N RRRN Add register and immediate (-1 and 1..15).
BEQZ.N RI16 Branch if register is zero with a 6-bit unsigned offset (forward only).
BNEZ.N RI16 Branch if register is non-zero with a 6-bit unsigned offset (forward only).
BREAK.N2 RRRN This instruction is the same as BREAK but with a 16-bit encoding.
L32I.N RRRN Load 32 bits, 4-bit offset
MOV.N RRRN Narrow move
MOVI.N RI7 Load register with immediate (-32..95).
NOP.N RRRN This instruction performs no operation. It is typically used for instruction alignment.
RET.N RRRN The same as RET but with a 16-bit encoding.
RETW.N3 RRRN The same as RETW but with a 16-bit encoding.
S32I.N RRRN Store 32 bits, 4-bit offsetif seems when executing S32I.N RRRN Store 32 bits, 4-bit offset it triggers the issue, This may be more information then I need but I think I have an idea of what is triggering it but I am uncertain on how to locate the calling function without laying a bunch of printf's everywhere. Anyone know how to get a call stack or get additional details?
Update2:
So I appended this check to each of my alloc's before the memset's got to them and it seemed to have resolved the issue.
if (FormatedHTMLPage == 0x0)
os_printf("[%s][%s][%d] - Unable to Alloc memory, exiting\r\n", __FILE__ ,__func__, __LINE__);
return;
The larger issue is I only have about 25k of heap to have a client connect via WPA-PSK2 and then send it a detailed webpage.
The page itself is almost 8k in side. Anyone know of an easy way to send this waypage with dynamic configurations inside?
The way I have it now is its loaded in flash and it reads it into a GlobalVar at the start. Yes sadly this takes a var kinda like this
char webpage[8192] = SPiRead(WebpageInSPIRom)
Then I have to allocate another for sprintf to then change my variables before I shoot it off to the client.
Problem is thats 16k raw just to format the data in memory. Any pointers would be greatly appreciated!
Update3: Here is my latest error @ 0x40101074
IP Address: 192.168.1.51
Netmask : 255.255.255.0
Gateway : 192.168.1.1
Calling myConnectToStronestWifiCallback callback
[Main.c][EnterMaintainanceMode][537]
AP Already Loaded[../library/webserver.h][init_webserver][786]
Setting Callback for WebServer
[../library/dnsserver.h][init_dnsserver][170]
-=-=-=-=-=-=-=-=- START DumpSPItable -=-=-=-=-=-=-=-=-
Read from: 0x67004-0x67007, Pending ff: EOF!
-=-=-=-=-=-=-=-=- END DumpSPItable -=-=-=-=-=-=-=-=-
[init_igmp]
IGMP Joining: 3301a8c0 faffffef, joined
Fatal exception 9(LoadStoreAlignmentCause):
epc1=0x40101074, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x0�000000
tail 0
chksum 0xcd
load 0x3ffe8890, len 22224, room 8
tail 8
chksum 0x44
tail 0
chksum 0xc8
csum 0xc8
����n�r��n|�llll`b��|r�l�n��n�l`��r�l�l�l`��r�l�l�l`��r�l����5����c][user_init][765]
[../library/../library/common.h][Common_UserInit][1412]
sleep disable
Loaded from: 0x00
Vdd33_Const: ff
rodata: 0x3ffe8890 ~ 0x3ffedf60, len: 22224
bss : 0x3ffedf60 ~ 0x3fff4a98, len: 27448
heap : 0x3fff4a98 ~ 0x3fffc000, len: 30056
reset reason: 2
REASON_EXCEPTION_RST (9)
[GetEXCCount]
[StoreEXCCount] creating with: 1
epc1=0x40101074, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x00000000
System halt!Anyone know how to see the function call at address's greater then 0x40100000? With this new EPC1 value it seems its assigned to the mapping of IRAM1.. Am I on the right track, should I objdump the Main.o and review the offset 0x1074 within?
Any pointers in the right direciton would be greatly appreicated.
