I've been on 2.1.0 for quite sometime and decided to take the leap to 3.0.0. After I did I started experiencing intermittent connection issues with my Wifi. Then also creating a snapshot I moved back to 2.1.0 and everything works great again. I also tested 3.0.1 and 3.0.2 and all yield the same issue and rolling back to 2.1.0 everything works. Does this having something to do with the new RF_CAL param added in userland or something else I may be missing from my upgrade? Any help would be amazing as I am currently stuck in the water right now with this specific issue.
As you can see in the first picture that is of my NONOS SDK 2.1.0. In the 2nd is the same exact code running on 2.2.0 and I get the same results and error each time unless I revert back to 2.1.0. It almost seems like when I do my Station_Init something in the new SDK or maybe the way I MAKE the sdk is jacking up the Radio. It seems at runtime the radio gets stuck in an off position or something I am not seeing but the 2.1.0 you see it kick off with "mode: 0 -> 3" and yet you never see that happen in the new versions. It seems like something in the SDK changed the behavior of connecting via Wifi? Futhermore, When I do a custom scan I can see one accesspoint that is on channel 9 but not my default "HHN" network that is on channel 6.
To add, This may be an issue on how I am upgrading my SDK. I use PFalcon's toolchain and modify the make file to include the other sdk's then run the following.
make clean-sdk clean-sysroot all
Once completed I have to run a few post commands to fix a few things to get my SDK to run.
Fix1: Copy all the ld files located in esp-open-sdk/ESP8266_NONO_SDK-{VER} -> esp-open-sdk/xtensa-lx106-elf/sysroot/usr/lib. I then have to go into the files and update the include locations within the files to correct this.
/* get ROM code address */
INCLUDE "../ld/eagle.rom.addr.v6.ld" -> INCLUDE "/eagle.rom.addr.v6.ld"
Fix2:[osboxes@osboxes i2c]$ make fresh
xtensa-lx106-elf-gcc -Teagle.app.v6.ld main.o -nostdlib -Wl,--start-group -lmain -lpwm -lnet80211 -lwpa -llwip -lpp -lphy -lc -Wl,--end-group -lgcc -o main
/home/osboxes/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.5/../../../../xtensa-lx106-elf/bin/ld: main section `.text' will not fit in region `iram1_0_seg'
/home/osboxes/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.5/../../../../xtensa-lx106-elf/bin/ld: region `iram1_0_seg' overflowed by 956 bytes
make: *** [main] Error 1
To fix this I then have to copy the libgcc.a to and from the location below
esp-open-sdk/ESP8266_NONO_SDK-{VER}/lib/ -> esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.5
Any pointers would be super helpful if you find anything I may be doing here may be breaking my functionality.
