The example code has not been modified and I have already successfully tested other examples.
I don't have MPU6050 connected !
I made the git clone again from the repository and run the commands:
make menuconfig
make -j4 flash monitorLogs:
Leaving...
Hard resetting via RTS pin...
MONITOR
--- idf_monitor on COM8 74880 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
load 0x40100000, len 7168, room 16
tail 0
chksum 0x6d
load 0x3ffe8408, len 24, room 8
tail 0
chksum 0xe4
load 0x3ffe8420, len 3532, room 8
tail 4
chksum 0xc7
I (43) boot: ESP-IDF v3.2-493-g0b390d81 2nd stage bootloader
I (43) boot: compile time 08:53:03
I (43) qio_mode: Enabling default flash chip QIO
I (51) boot: SPI Speed : 40MHz
I (57) boot: SPI Mode : QIO
I (63) boot: SPI Flash Size : 2MB
I (70) boot: Partition Table:
I (75) boot: ## Label Usage Type ST Offset Length
I (86) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (98) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (109) boot: 2 factory factory app 00 00 00010000 000f0000
I (121) boot: End of partition table
I (128) esp_image: segment 0: paddr=0x00010010 vaddr=0x40210010 size=0x19690 (104080) map
0x40210010: _stext at ??:?
I (175) esp_image: segment 1: paddr=0x000296a8 vaddr=0x402296a0 size=0x04390 ( 17296) map
I (182) esp_image: segment 2: paddr=0x0002da40 vaddr=0x3ffe8000 size=0x003c8 ( 968) load
I (187) esp_image: segment 3: paddr=0x0002de10 vaddr=0x40100000 size=0x00a50 ( 2640) load
I (200) esp_image: segment 4: paddr=0x0002e868 vaddr=0x40100a50 size=0x04bb4 ( 19380) load
I (220) boot: Loaded app from partition at offset 0x10000
I (240) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (244) system_api: Base MAC address is not set, read default base MAC address from EFUSE
phy_version: 1163.0, 665d56c, Jun 24 2020, 10:00:08, RTOS new
I (311) phy_init: phy ver: 1163_0
I (313) reset_reason: RTC reset 2 wakeup 0 store 0, reason is 2
I (409) gpio: GPIO[14]| InputEn: 0| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
I (413) gpio: GPIO[2]| InputEn: 0| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x40211f1c
0x40211f1c: _esp_error_check_failed at C:/msys32/home/leonardo/esp/ESP8266_RTOS_SDK/components/freertos/port/esp8266/panic.c:206
file: "user_main.c" line 203
func: i2c_example_master_mpu6050_init
expression: i2c_example_master_mpu6050_write(i2c_num, PWR_MGMT_1, &cmd_data, 1)
abort() was called at PC 0x40211f1f on core 0
0x40211f1f: _esp_error_check_failed at C:/msys32/home/leonardo/esp/ESP8266_RTOS_SDK/components/freertos/port/esp8266/panic.c:207
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x402191a2 PS : 0x00000030 A0 : 0x402191a0 A1 : 0x3ffebb80
0x402191a2: abort at C:/msys32/home/leonardo/esp/ESP8266_RTOS_SDK/components/newlib/newlib/port/syscall.c:168 (discriminator 1)
0x402191a0: abort at C:/msys32/home/leonardo/esp/ESP8266_RTOS_SDK/components/newlib/newlib/port/syscall.c:168 (discriminator 1)
A2 : 0x00000000 A3 : 0x00000001 A4 : 0xffffffdb A5 : 0x00000001
A6 : 0x00000000 A7 : 0x4022b524 A8 : 0x3ffe9670 A9 : 0x00000090
A10 : 0x4022c986 A11 : 0x00000020 A12 : 0x00000000 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000001e EXCCAUSE: 0x0000001d
Backtrace: 0x402191a2:0x3ffebb80 0x40211f22:0x3ffebb90 0x40213ae4:0x3ffebba0 0x40213c1c:0x3ffebbc0
0x40211f22: _esp_error_check_failed at ??:?
0x40213ae4: i2c_example_master_mpu6050_init at C:/msys32/home/leonardo/esp/i2c/main/user_main.c:204
0x40213c1c: i2c_task_example at C:/msys32/home/leonardo/esp/i2c/main/user_main.c:226
I am using NodeMCU ESP8266 LoLin V3, I have already tested it with other cards and the result is the same.
Does anyone succeed in running this example from the current version ?
