By Jean Charles
#89372 I am working on a simple circuit (for debugging purpose) which switches a 3V3 relay every second through the Esp-01 GPIO2 pin. The power supply comes from the USB to ESP-01 adapter (but the same happens with another power supply)
This circuit is the following:
Code: Select all  **ESP8266-01:**
    VCC <--> 3V3 power supply
    GND <--> GND (power supply)
    CH_PD <--> 3V3 power supply
    GPIO2 <--> IN (relay)
    **3V relay:**
    IN <--> GPIO2 (ESP-01)
The relay is mounted on a power extension cord, on which I can connect various devices.
Here is my circuit diagram (the breadboard is not represented): Image
My sketch is the following:
Code: Select all  #include <ESP8266WiFi.h>
    const int switch_pin = 2;
    int state = 0;
      WiFi.forceSleepBegin();
      pinMode(switch_pin, OUTPUT);
      if (state == 0){
        digitalWrite(switch_pin, HIGH);
        state = 1;
        Serial.println("1");
      else{
        digitalWrite(switch_pin, LOW);
        state = 0;
        Serial.println("0");
      delay(1000);
which produces, on the serial:
Code: Select all  0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
     ets Jan  8 2013,rst cause:4, boot mode:(3,7)
    wdt reset
    load 0x4010f000, len 3584, room 16
    tail 0
    chksum 0xb0
    csum 0xb0
    v2843a5ac
    ~ld
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    0
    1
    wdt reset
    tail 0
    chksum 0xb0
    csum 0xb0
    v2843a5ac
    ~ld
Thus, sometimes, the Esp-01 resets and, sometimes it cannot "recover" from such resets.
However, when I disconnect the extension cord (from the electrical outlet in the wall), the relay switches indefinitely as expected (I do not know if it's a clue to solve my problem).
I tried with 2 relays and 2 Esp-01 and always got the same behaviour.
Would you have any idea about the origin of such a problem?
