For 2N7002, maximum switching (drain-source) voltage is 60V and maximum continuous gate (gate-source) voltage is 20V. Applying 60V to the gate of the device would destroy it.
However, it is true that the on state resistance of mosfets is normally lower with 12V gate drive than with 3.3V gate drive, but "logic" drive mosfets are available which have lower gate threshold voltage and which, if selected correctly, have sufficiently low on state resistance with a gate drive of 3.3V.
AusUser wrote:If that is all correct then I would suggest that you try using the Temp pin (pin 8) of the TP4056 to disable charging. - See more at: viewtopic.php?f=160&t=13745&start=4#sthash.kFnkw8eG.dpuf
Thats correct. And thanks for such a detailed response this sounds like a good options. Just to note the LTC4150 can be set to provide 3.3v output to the ESP8266. The solar panel will output 5V to the TP4056
As an alternative could I also use a 2N7000 or similar to do the switch?
Thanks I have BS170 in the box, I'll give that a go.
