I need wire Gpio2 with echo pin on hc-sr04 (ultrassonic sensor) but every time I go to download mode on power up, if i power esp without connect echo pin all works well (connecting pin after boot process)
Any hint?
Thks and sorry about bad english
Explore... Chat... Share...
