Burnt out first ESP-12E, help me avoid doing it again
Posted: Tue Dec 27, 2016 2:51 pm
I have 2 ESP-12E boards I bought on Amazon (from Maker Focus). I have it plugged in to my laptop via USB. The first board was continiously not working properly it seems like it would just reboot every few seconds. While attempting to troubleshoot I somehow (not sure exactly) fried the board ( I could smell it).
I was trying to use a very script:
But it kept rebooting and the LED wouldn't flicker consistently. I was guessing it might be related to the input voltage from the USB, but before I try again with my (last) board I wanted to find out if my laptop USB port is a valid output of power for the board?
Link to the actual boards:
https://www.amazon.com/Makerfocus-ESP82 ... B01IK9GEQG
// the setup function runs once when you press reset or power the board
// initialize digital pin 13 as an output.
Serial.println("Welcome");
Serial.flush();
pinMode(D2, OUTPUT);
// the loop function runs over and over again forever
Serial.println("Test1");
Serial.flush();
digitalWrite(D2, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println("High");
Serial.flush();
delay(100); // wait for a second
digitalWrite(D2, LOW); // turn the LED off by making the voltage LOW
Serial.println("Low");
Serial.flush();
Serial.println("Test2");
Serial.flush();
