AT+CIPSEND=098
OK
se
busy s...
Recv 98 bytes
busy s...
SEND OK
PS: I am using Tiva Launchpad TM4C123GXL. I have made functions Commandprintln and Commandprintln to send commands to ESP, while println just gives output to FTDI which is connected to PC.
CODE for Initialising ESP8266
char StartModule()
//reset and test if the module is ready ------------------------------------------------------------------------------------------------------
bool module_responding = false;
bool connected_to_access_point = false;
bool connected_to_dweet = false;
int connection_attempts = 0;
char cmd[100] = "AT+CWJAP=\"";
char cmd1[100] = "";
println("Starting module");
while(!module_responding){
Commandprintln("AT+RST");//reset module (works with both ESP-01 and ESP-03 module)
if (wait_for_esp_response(5000, "ready")){ //watch out for the case of the r in ready - varies with ESP8266 firmware version
println("Module is responding");
module_responding = true;
else{
println("Module not responding to reset");
delay(1000);
Commandprintln("AT+GMR");
wait_for_esp_response(1000,OKrn);
Commandprintln("AT+CWMODE=1");
Commandprintln("AT+CIPMUX=0");
println("Connecting to WiFi access point...");
Commandprintln("AT+CWQAP");
delay(100);
strcat(cmd,SSID);
strcat(cmd, "\",\"");
strcat(cmd,PASS);
strcat(cmd,"\"");
println(cmd);
Commandprintln(cmd);
delay(5000);
connected_to_access_point = wait_for_esp_response(9000,OKrn);
if(!connected_to_access_point){
println("Attempt to connect to access point failed. Restarting module.");
return false;
println("CONNECTED TO ACCESS POINT");
println("Connecting to dweet...");
while((!connected_to_dweet)&&(connection_attempts < MAX_SERVER_CONNECT_ATTEMPTS)){
memset(cmd1,'\0',100);
strcat(cmd1,"AT+CIPSTART=\"TCP\",\"");
strcat(cmd1,URL);
strcat(cmd1,"\",");
strcat(cmd1,PORT);
Commandprintln(cmd1);
delay(1000);
println(cmd1);
connected_to_dweet = wait_for_esp_response(9000,OKrn);//this needs to change - look for something in server response that indicates valid connection
connection_attempts += 1;
if (!connected_to_dweet)
println("Attempt to connect to dweet did not succeed");
println("CONNECTED TO DWEET");
return connected_to_dweet;
}CODE FOR sending request
void loop(void) {
//char dweet[200] = "";
memset(sig_string,'\0',200);
memset(temp,'\0',3);
len = 80;
//Special appraoch required for floating point value here.
//Have to use dtostrf instead of sprintf since sprintf doesn't
//support floats on Arduino.
strcat(sig_string,"98"); //convert from character buffer array to string so
//white space can be cleared with .trim().
len += strlen(sig_string);
len+= strlen(sig_string);
len += (sizeof(thing_name) - 1);//sizeof will return 11 for a 10 character thing name because of null terminator
//so subtract 1
get_dec_str(temp,3,len);
//form and send the HTTP POST message
Commandprint("AT+CIPSEND=");
Commandprintln(temp);
println("AT+CIPSEND=");
if (!wait_for_esp_response(9000,"> ")){
Commandprintln("AT+CIPCLOSE");
println("send timeout - resetting wifi module");
delay(2000);
//StartModule();
StartModule();
delay(3000);
Commandprint("GET /dweet/for/");
//Serial.print(F("GET /dweet/for/"));// both POST and GET work
Commandprint(thing_name);
Commandprint("?temperature=");
Commandprint(sig_string);
Commandprint("&humidity=");
Commandprint(" HTTP/1.1\r\n");
Commandprint("Host: dweet.io\r\n");
Commandprint("Connection: close\r\n");//in some cases connection needs to be closed after POST
// Commandprint("Connection: keep-alive\r\n");//in this case we want to keep the connection alive
Commandprint("\r\n");
wait_for_esp_response(9000,"}}}\r\nOK");
delay(2000);
Ramp+=17;
if(Ramp>99){
Ramp=10;
Sig = 65*(2 * 3.142 * freq * 55 / 1000);
}main function
int main(void)
setUp();
while(!StartModule()){
delay(1000);
println("***Calling StartModule Again***");
while(1){
loop();
println("YEAH MAN"); //dummy
delay(1000);
